Command Line add multiple models with different configurations
Schoggi
(@schoggi)
I have to use the PrusaSlicer via the command line. I want to import 2 models at the same time and use a different configuration for each. The models have to be combined, therefore seperate slicing is not an option. Is this possible?
What I have so far: --export-gcode --merge model1.stl model2.stl --load slicer-config.ini
Opublikowany : 25/05/2020 12:37 pm
towlerg
(@towlerg)
RE: Command Line add multiple models with different configurations
Perhaps none of my business but curious why you would "have" to use CLI?
Opublikowany : 25/05/2020 12:53 pm
Schoggi
(@schoggi)
@towlerg
I'm writing an application and the backend calls the slicer via console.
Opublikowany : 26/05/2020 8:05 am
