combination of hardware and filament settings
Crusing Chemist
(@crusing-chemist)
I print a lot of special materials (FLEX, PA, PP,...) and all the settings are a combination of the filament and hardware settings. What i do right now is to create a project eg. FLEX and then i import the stl to this project, because all the settings (speed, retracting, filament temperature, bed temperature, skirt/brim) are in it. Is there a easier way to achieve this?
Thanks
Opublikowany : 25/11/2025 8:32 am
_KaszpiR_
(@_kaszpir_)
RE: combination of hardware and filament settings
Unfortunately not.
Opublikowany : 26/11/2025 12:01 am
That's as easy as it gets. I print a lot of objects (dog whistles) that only differ in the text printed on them. For that, I have one 3mf project with all my settings and then simply use "replace STL" to load the new customized object. That works fine as long as you don't have modified your object with paint on seams, supports, etc. They have to be redone.
Opublikowany : 26/11/2025 7:26 pm
1 ludzie polubili
