Colour Change Slider Issue
I'm not sure what setting changed but I can no longer move the layer slider by one layer at a time. When I move
it up and down it will jump for example from 4.40 to 4.20 to 4.10 as I slide it downward etc. I've hunted high
and low for a setting change and can't find anything.
RE: Colour Change Slider Issue
If I use a mouse with a scroll wheel and the model does not have supports, then the scroll wheel moves up or down, one layer at a time.
as does the cursor controls
when there are supports, the layer movement is different
@joantabb
Thanks for that.
I had it working yesterday but obviously I forgot. Getting old ain't easy.
as does the cursor controlswhen there are supports, the layer movement is different
I had mentioned that I had it working because of your reply. After a bit more time I realized my mouse scroll wheel had packed it it. I purchased a new rodent and now with the scroll wheel it will move it one layer at a time.
