Colour and temp change on the same layer
lutgendorff.film
(@lutgendorff-film)
Hello,
I'm trying to enact a colour and temperature change on the same layer of a print. I'm using an MMU3 on an MK3S and Prusa slicer, all up to date.
When I import my part I usually use the auto-detection for the colour change, but when I try to add custom g code to the same layer the pop-up box doesn't appear. Is this a bug? Is there a way around it? Or do I need to manually input the code that changes the extruder and the nozzle temp without using the auto-detection?
Thanks
Publié : 26/09/2024 6:31 pm
RE: Colour and temp change on the same layer
If you are assigning extruders to different colours I think PS doesnt let you do a colour change by  layer.  Its either/or I think.
However is you can attach a sample project her (file>save project as) and then zip up the 3mf produced and attach it then I'm sure someone will take a look.
Publié : 26/09/2024 6:58 pm
