Color Change Not Showing Filament Usage?
Delarado
(@delarado)
Guys,
https://help.prusa3d.com/en/article/color-change_1687
From this article:
However, from 2.3.0 with a color change configured...
Do I need to configure something else to make this work right?
EDIT: The reason I wanted this is so I could manually adjust octoprint filamentmanager filament usage after I printed, but it seems even if the Slicer did show me the different materials, it only shows the time and not the usage.
Anyone know of other workarounds?
Best Answer by FoxRun3D:
What hardware are you running it on? On Windows, it definitely shows the information. Meters and grams under "Sliced Info" in the right sidebar, and time per color under "Color Print".
Questa discussione è stata modificata 5 years fa da Delarado
Postato : 27/01/2021 11:06 am
RE: Color Change Not Showing Filament Usage?
Postato : 27/01/2021 12:36 pm
Delarado
(@delarado)
@fuchsr
I'm on a mac. What I'd like to see is how many grams/meters of each color is used, but it seems thats not the information provided.
My OSX slicer shows information as yours does.
Postato : 27/01/2021 1:38 pm
@delarado
Yeah, I can see why that would be useful.  But I don’t think there’s a breakdown of grams/meters by color.
Postato : 27/01/2021 2:14 pm
It only keeps track per extruder.  So a multi extruder system like a mmu you get grams per extruder I believe.
Postato : 27/01/2021 2:22 pm
