Color Change Issue
SnowEagle
(@snoweagle)
Color Change Issue
When making a color change, everything with the change works great but just before the extruder moves it spits out a small amount of filament. This is all setup automatically by PrusaSlicer using the Layer slider. How can I stop this from happening.
;BEFORE_LAYER_CHANGE
G1 E-0.04000 F1800.00000
G1 F5760
G1 X171.252 Y50.617 E-0.34200
G1 E-0.01800 F1800.00000
G1 Z1.000 F7200.000
;AFTER_LAYER_CHANGE
; PRINT_COLOR_CHANGE
M600
G1 X76.501 Y149.732
G1 E0.40000 F1800.00000
M204 S600
G1 F1200
Opublikowany : 18/03/2020 12:38 am
Area51
(@area51)
RE: Color Change Issue
This "feature" is part of the firmware and can not be controlled by g-code. Some sees this as a plus avoiding holes in perimeter (PLA). Other sees this as a problem as the extra extrude can be dragged around and make more damage than good (PETG).
The extra extrude has been discussed on the forum and reported as an issue several times:
[BUG] Extra extrusion after filament change #2502
Opublikowany : 18/03/2020 3:38 am
SnowEagle
(@snoweagle)
@area51
Thanks for the info!
Opublikowany : 18/03/2020 1:01 pm
