Color Based Settings
SnowEagle
(@snoweagle)
Is there a temperature setting rule of thumb based on filament color?
As in Black vs White.
Napsal : 13/02/2022 4:06 pm
The rule of thumb is:
Follow the manufacturer's suggestions, or use presets for that filament where available.
Only if there are issues do you need to worry about colour; some filaments, including white/pale/pastel, *might* be better printed a few degrees hotter than others in the same range.
Napsal : 13/02/2022 5:18 pm
RE: Color Based Settings
I would start with the stock settings and if I run into issues, print a temperature tower.
Napsal : 13/02/2022 6:39 pm
