[Solved] Clone printer settings
Jakub Čermák
(@jakub-cermak)
Hi, is it possible to clone printer settings including print settings (layers) ?
I want to create separate printer profile for 1mm nozzle. In old slic3r I just did the changes to the printer profile and saved it under a new name and everything including profiles got copied to the new printer settings. But in current version everything looks promising at the first, but then after restarting prusaslicer, all profiles that I created under the new printer (based on the system print profiles) are now under old printer profile. Sometimes it crashes and I have to clean wipe all profiles and create them again from scratch.
Napsal : 26/03/2020 10:04 am
RE: Clone printer settings
I just replied to a different thread but possibly related ?  https://forum.prusa3d.com/forum/prusaslicer/settings-have-all-disappeared/
Napsal : 26/03/2020 2:41 pm
1 lidem se líbí
Jakub Čermák
(@jakub-cermak)
@neophyl
thanks, it was partly related (one part of the problem), other part was the "compatible printer condition" settings that I didn't know about and I discovered it because of your advice because it's on the same settings page 🙂
Thanks
Napsal : 26/03/2020 2:54 pm
