Changing speed during printing
Erwin
(@erwin-2)
Hello All,
Is there a way to change the speed of printing at a certain layer. I have a print with a lot of low parts but also some thin long parts.
I'm afraid that during printing all the low parts will be fine and have enough time to cool down, but the small high part not.
Thanks for any advice using Prusaslicer
regards,
erwin
Respondido : 25/08/2020 2:25 pm
RE: Changing speed during printing
Sounds like you need to set the cooling settings under filament>cooling for your parts.  Basically that allows you to control the printing time/speed if the layer time is below a certain value.  That allows extra time for cooling.
Although with very thin tall parts the usual work around is to print 2 of them.  That way the extruder alternates between them allowing extra time for each to cool.
Respondido : 25/08/2020 2:36 pm
