Changing sla material in Slicer 2.2
kevin.p24
(@kevin-p24)
I'm trying to change the material from Prusa Orange Tough to Grey Tough - how do you do it?
I've tried using the material settings and the drop box on the top right hand side but there is no alternative resin, and the default orange one is locked.
When I go through the configuration wizard the grey material is in the list (ticked) and I select them all but nothing happens - I cant change the resin.
Help
Publié : 04/05/2020 10:37 am
Lichtjaeger
(@lichtjaeger)
RE: Changing sla material in Slicer 2.2
Most resins are only available on 0.05mm layer height. For 0.035mm and 0.01mm layer profiles you need to set up the resin profiles yourself.
Setting the exposure times to 20% of the 0.05mm value for 0.01mm layers or respectively 70% for 0.035mm layers usualy works fine.
Publié : 04/05/2020 11:19 am
kevin.p24
(@kevin-p24)
Thanks for the reply, but I was expecting the slicer panel to have the materials available to select (as it does with the filament)?
So when the SLA Material box arrow is clicked a drop down menu of the resins in the "SLA Material Profiles Selection"(as in the configuration wizard) would appear?
Thanks
Publié : 04/05/2020 11:41 am
