Changing Infill/perimeters overlap mid-print
I am seeking a method for changing the Infill/perimeters overlap setting mid-print. I did not see a way to do this through a mock filament change as the Infill/perimeters overlap setting is in Print Settings, not Filaments. I am using a CORE One +, single extruder, and the PrusaSlicer silcer.
For context: I am working on a translucent print with clear PMMA. The current issue is that as the print progresses air pockets begin to form where the infill and perimeter meet. Increasing the infill and perimeter overlap delays the onset of the air pockets. With the last overlap setting that I tried there were still air pockets forming by the end of the print and the start of the print was bulging at the seam from overextrusion.
An alternative approach that I haven't tried is to see if changing the extrusion multiplier between filament changes counteracts the bulging at the start. One thing about that approach is I would want to figure out how to remove the actual filament change procedure. PMMA is quite brittle and snaps when unloaded by the default procedure. It'd be very helpful if it could "change filaments" without physically changing filaments.
Thanks for reading!
