Changing filament assignments for a Multimaterial painting
Wes
 Wes
(@wes-4)
Suppose I have a 3mf file in which a model has already been "painted" with the multimaterial painting option.
I have similar colors loaded up to the MMU3, but they are in a different order than in the original painting.
Can I change the extruder order for the painting in software, without redoing the painting? Or do I need to physically change the filament setup at the
MMU3?
Thanks!
Wes
Questa discussione è stata modificata 2 years fa da Wes
Postato : 30/01/2024 11:14 pm
SomeJW
(@somejw)
Utenti
RE: Changing filament assignments for a Multimaterial painting
I am hunting for the answer to the same question. Guess you have not received one yet.
Postato : 04/06/2024 6:24 pm
I believe with painting, you need to move the filaments to match the paint scheme
Joan
Postato : 04/06/2024 9:54 pm
mander
(@mander)
Any update on this.   It seems the multi painting tool should have a swap spool option where I can say select spool 1 and say "swap to spool x" and it would make global update so you don't need to go repaint every block. or swap spools around, as both are time consuming for some models.
Postato : 13/02/2025 1:01 am
Badfurball
(@badfurball)
Utenti
Looking for an update to this info as well. Not being able to switch which extruder is assigned to the Multilateral Paint is not acceptable. I have an XL and one of the extruders is down, waiting for replacement parts from Prusa. This feature should have been an expected one when it was implemented.
Postato : 25/03/2025 1:24 am
deneva
(@deneva)
Utenti
Posting to keep this alive, as I agree that this should be an expected feature need for multi-color/material printing.
Postato : 13/04/2025 7:55 pm
On My Mk3.9 with MMU3,
you can load a print file,
then you select print
then you get the filament allocation table where you can change the filament type
IF you rotate the LCD selector Backwards you get the option to either re allocate the filaments or use spool join.
I have only re allocated one filament in a session so far, but It's worth trying to re allocate more filaments
as I no longer have an MMU3 on my Mk3S I can't try this feature there...
I Suspect it would be restricted to 32bit controllers, only.  Mk4, Mk3.9, Mk3.5.
Postato : 13/04/2025 8:26 pm
Cody
 Cody
(@cody-5)
Utenti
I have found a way to do this. It's a bit involved, and I'm not sure if it will work with all files, but it worked for me. I used 7-Zip to access the files and Sublime Text to edit the files in some of the steps, but there may be other programs that work as well.
1. Load the project file into PrusaSlicer. I am using version 2.9.2
2. Change the object's extruder to extruder 2. The whole thing will be the same color, but we'll fix it later.
3. Save the project file as a new file.
4. Open the new 3mf file that you have created in 7-Zip, go into the 3D folder, and export the 3dmodel.model file into a folder on your computer.
5. Open this file in Sublime Text. I use Sublime because it has advanced search and replace features, but they are not needed here. Even notepad would work.
6. Search (ctrl+f) for 'slic3rpe:mmu_segmentation="8" '.  Also search for 'slic3rpe:mmu_segmentation="4" '. This is the field that tells the program which extruder color it was painted with. If both are found, move onto the next step. If 'slic3rpe:mmu_segmentation="8" ' is the only one found, skip the next step. If 'slic3rpe:mmu_segmentation="4" ' is the only one found, skip the next next and swap the 4 and 8 in the next steps. If neither are found, search for mmu, and use the string you found in the next steps.
7. Replace (ctrl+h) all 'slic3rpe:mmu_segmentation="4" ' with an empty string. This changes all triangles that were painted with extruder 1 to use the one we set the object to in step 2.
8. Replace (ctrl+h) all 'slic3rpe:mmu_segmentation="8" ' with 'slic3rpe:mmu_segmentation="4" '. This changes all triangles that were set to use extruder 2 to use extruder 1. If anyone has any ideas to why it is 4 and 8 instead of 1 and 2, let me know. My best guess is it's using the 4 and 8 bits, but the why not the 1 and 2 bits?
9. Save the file
10. Copy the file back into the 3mf file where you got it from, overwriting the one that is in there.
11. Import the project into PrusaSlicer, it should be reversed!
Postato : 25/04/2025 3:58 am
1 persone hanno apprezzato
jhuston
(@jhuston)
Utenti
The above post was very helpful to me. To take it a bit further. I found the following to be true on my MMU. The sequence of the extruders is: 4,8,0C,1C,2C
In case you need to go past the first couple.
Postato : 13/10/2025 2:23 pm
wijwoj
(@wijwoj)
Utenti
How is this not a feature in PrusaSlicer?
Postato : 21/10/2025 10:34 pm
wijwoj
(@wijwoj)
Utenti
Feature has already been requested here https://github.com/prusa3d/PrusaSlicer/issues/14903. Please add some comments to get visibility.
Postato : 22/10/2025 10:23 am
Michael
(@michael-12)
Fixed link to the Github issue:
Can't believe this isn't a feature already.
Postato : 22/10/2025 10:08 pm
