Change Seam position midprint?
TeachThePrints
(@teachtheprints)
Is there any way to adjust the seam position midprint in PS 2.5?
I have a print, where the bottom half prints without visible seam when set to "Rear" and the top half, when set to "Nearest". So atm. I can either half a flawless bottom or top half. Ideally, I'd use "Rear" and then switch to "Nearest" after 150-off layers.
Is this possible?
Best Answer by Neophyl:
Just use the seam painting tool.  Set to aligned and then paint the areas where you want the seam to be (seam painting is on the left side tool bar, shortcut of P)
Prusa Mini FW6.2.4
Publié : 11/11/2022 9:10 am
RE: Change Seam position midprint?
Publié : 11/11/2022 9:25 am
TeachThePrints
(@teachtheprints)
Thanks. Easy fix.
Prusa Mini FW6.2.4
Publié : 11/11/2022 12:33 pm
