Change Infill and gaps
Tonino
(@tonino)
hello guys,
as you can see I tryed to set a different infill but PS created some gaps in the first layer and on the top layer; do you know how can I change the infill avoiding effects on the top/bottom layers?
thanks
Veröffentlicht : 02/03/2020 7:01 am
RE: Change Infill and gaps
The gaps are from the modifier you are applying.  Basically it needs to not intersect with the shell at all.  Slicer is treating the 2 areas differently and so its path planning causes that discontinuity.
I think its actually a bug with the meshes. I seem to recall someone opened an issue over on github about it.
Veröffentlicht : 02/03/2020 7:15 am
Fabi
 Fabi
(@fabi)
I think this is an current bug in PS.
My workaround is to avoid the modifier touching the top and bottom layer. Adjust the size of the modifier so he only affects the internal infill and move it some layer over the build plate. Its a bit a cumbersome procedure but it works
Veröffentlicht : 02/03/2020 10:03 am
Fabi
 Fabi
(@fabi)
Just discovered, it will be fixed in next release of PS, see heere:
https://github.com/prusa3d/PrusaSlicer/issues/2982
Test with current RC1:
Veröffentlicht : 02/03/2020 12:00 pm
@fabi
I wasnt keeping track that much (I was in the github thread you linked to) but its good to see that its been fixed in the rc.
Veröffentlicht : 02/03/2020 12:12 pm
