Change in diameter of print
I have drawn a shape in Fusion 360 and printed successful versions at 100% and 75% scale. When I print a 50% copy, made by reducing in Fusion or in Prusaslicer, they come out flawed in the same way. Is there an explanation why these prints fail? The OD should be a smooth curve, but it has reduced diameter in the center that does not appear in the Prusaslicer preview.
RE: Change in diameter of print
Search for the term 'buldge' on the forum. Yes I know its not spelt correctly. There are pages and pages about this effect.
Thanks for the "heads up". I see I am late to the party. My shape has a 3 layer wall, and where the diameter changes, the slicer preview shows a color change from yellow to white. What does this indicate? It shouldn't be infill, because I have 4 perimeters.
If I choose a 60% scale instead of 50% the preview shows all yellow interiors. I'm trying to print one with Simplify3D now (I would hate to go back to this). When it finishes I'll try a 60% model and see if the buldges go away.
White is gapfill. You could try arachne if you aren't already as that should get rid of gapfill but nothing seems to be a sure fire thing to get rid of it. A lot of what you are picturing looks like plastic contraction. Which could be down to so many factors (or a combination).
Without seeing the project and being able to slice with exactly the same settings and run through the various preview options to get a better idea of what the slicer is doing its hard to tell for certain. Is it going at a different speed on those sections ? does that area get a different amount of airflow due to the duct design ? So many possibilities.
