Can't Slice anything
Tyler Wingfield
(@tyler-wingfield)
Hopefully this is an easy fix. I'm brand new to printing.
I downloaded Prusa Silcer, selected my ender 3 pro printer, watched a tutorial for the basics of print settings and filaments. Every model stl or obj I import ends up looking like the below photos when I click slice. It does it even if I hadn't made any changes to the model.
Anyone seen this??
Thanks for any help and let me know if any more screenshots would be helpful to diagnose.
Napsal : 03/08/2024 7:16 pm
RE: Can't Slice anything
Sounds like this one https://forum.prusa3d.com/forum/prusaslicer/strange-prusaslicer-2-8-0-issue-screen-filling-with-lines-and-triangles/
What OS are you on ?  If I were you I would report this over at the PS github page included all the required info for a new issue.  https://github.com/prusa3d/PrusaSlicer/issues
Could be something in your project but if you want someone to check then you will need to save your project from PS (File>Save Project As) and then take the 3mf produced, ZIP it up and attach it here.  If you don't zip it the forum simply wont attach the file.  A 3mf saved from PS will contain the model(s) but also just as important all the settings you are slicing with.
Napsal : 04/08/2024 12:02 am
Phil
 Phil
(@phil-11)
Posted by: @tyler-wingfield
Anyone seen this??
Napsal : 04/08/2024 7:29 pm
Phil
 Phil
(@phil-11)
Wow, one needs a PhD to operate such a machinery
Tyler Wingfield
(@tyler-wingfield)
Mac OS, same as the other poster.
I found their issue on github and i'm following up there.
Fingers crossed. Thank you!
Napsal : 04/08/2024 11:43 pm
