Can't enforce supports
namron
(@namron)
I got trouble with support. My PrusaSlicer ist up to date (v. 2.3.3).
Here are my support settings:
This is the support I want to enforce by paintinng it on. The screenshot is made looking up, from underneath the bed.
And this is the result after slicing:
It does not respect my support enforcers. In the right panel 'Support' is set to 'Everywhere'.
Am I doing it wrong or is this a problem with the slicer?
Best Answer by Neophyl:
You need to untick don’t support bridges.
Napsal : 21/08/2021 11:22 am
Zoltan
(@zoltan)
Member Moderator
RE: Re
You should set to "only enforced supports" it is an exclusion between all (slicer sets support everywhere it thinks should be, ignoring your enforced) and only forced which sets the supports only where you selected - the height of support must ať the supported part or higher,slicer will remove the rest above model.
Napsal : 21/08/2021 12:59 pm
namron
(@namron)
Re
If I set it to "For support enforcers only" no support is created at all.
Napsal : 21/08/2021 1:02 pm
namron
(@namron)
re
Posted by: @zoltan
sorry, I don't understand what you mean.
Napsal : 21/08/2021 1:04 pm
Zoltan
(@zoltan)
Member Moderator
Re
When the top of your support object does not reach the bottom of the supported part the slicer will not create that support -make you support object higher
Napsal : 21/08/2021 1:14 pm
Zoltan
(@zoltan)
Member Moderator
RE: Re
When the top of your (enforced)support object does not reach the bottom of the supported part the slicer will not create that support -make you support object higher
Napsal : 21/08/2021 1:17 pm
1 lidem se líbí
namron
(@namron)
re
Posted by: @neophyl
That solved it. Thank you.
Napsal : 21/08/2021 1:20 pm
