Can't change print settings for several parts simultaneously
Hello,
I have a complex object split in many parts. I want to change a few settings for a group of these parts but not the others. If I select a single part and perform a right-click, I can see many options to adjust print settings in the contextual menu. However if I select several parts I can't see these options in the menu anymore.
Is there a way of should I painfully adjust the settings part by part?
Opublikowany : 23/01/2026 5:29 pm
Group them together in the same part of the bed then add a modifier, size it to include all you want to change and apply the changes to the modifier.
Opublikowany : 23/01/2026 5:42 pm
2 ludzie polubili
