Cannot access user profiles linked to gmail after I formatted my PC
Hello,
I recently formatted my pc and tried to install prusa slicer. After the installation, I logged in with my gmail but i cant see my profiles where i had saved many many presets. Is there a way to restore those profiles?
Opublikowany : 22/02/2025 10:36 am
RE: Cannot access user profiles linked to gmail after I formatted my PC
Settings are not stored in the cloud, they are stored on your pc. If you reformatted it then they are all gone. Unless you made a backup of any user defined ones using the Export Config Bundle option ? Standard ones are added via the normal install wizard.
If you didnt have the foresight to do that then you are probably out of luck.
Opublikowany : 22/02/2025 2:14 pm
