Can Someone Give Me an Idiot's Guide to Setting Up a Photon Mono X?
Wingnut
(@wingnut-2)
I can't seem to create an SLA edit.  Whatever I try it keeps asking for nozzle and filament details!
If someone could walk me through setting up an SLA printer I'd be grateful.
Thanks
Publié : 25/04/2022 5:45 pm
Membre
RE: Can Someone Give Me an Idiot's Guide to Setting Up a Photon Mono X?
You want to use UVtools.
https://github.com/sn4k3/UVtools
Publié : 28/04/2022 1:01 am
Yveske
(@yveske)
@wingnut-2
Add a Prusa SL1 to your list of printers in PrusaSlicer using "Configuration - Configuration Wizard" and finish the wizard
In "Printer settings" change the "Max print height", "Display width" and "Display height"
Save the printer settings under a new name
Choose the new printer created above and insert your model
Hollow and add supports
Use "File - Export - Export plate as STL including supports" to export a hollowed and supported version of your model
Open Photon Workshop and import the newly created hollowed and supported model
Create gcode and put it on the stick to print
Use this Excel file as starting point for your settings.
Experiment a little using the included "R_E_R_F.pwmx" or UVTools as @cwbullet suggested to find the correct exposure
Know that you can change the starting exposure of the "R_E_R_F.pwmx" by changing settings on the printer, use the cogwheel after the print has started.
Enjoy your Mono X !
Having problems with bed adhesion every morning...
Publié : 28/04/2022 5:45 am
