Can PrusaSlicer add a customer support enforcer only above a certain layer?
I'm trying to support an overhang in a clamp I've designed.
I can easily add a custom suppoer enforcer around the overhang. Thats no problem at all and works very well and is how I've been using PrusaSlicer for many months. However now I want to add in a square volume in the bottom of the lug cutout. to hold a M3 square nut. If I put the custom support enforcer as I would normally
it now puts support in the hole inside the bottom lug.
I want to enforce the support but only above 5.15mm.
I've moved the support enforcer above 5.15mm and that doesn't work. I've added a customer support blocker underneath the support enforcer and that doesn't work either.
A redesign won't actually help here as if I put the m3 nut in the top lug, I have an same issue with the hinge on the other side.
Any help welcomed.
Thanks
Rob
I looked at the height modifer but that just does layer thickness (which is nice).
Best Answer by Ringarn67:
@rwillett
I read this post at work, where I don't have access to PrusaSlicer 😖, and immediately thought of one thing to try.
Never done it before, and when I got home and tried it, it works 😀
Design a support blocker in cad!
Support Blocker should be one body and part, obviously, one body. So, two bodies
Export as one stl and open in PS
Split to Parts
Set Support to Everywhere. Change it to "Snug" in "Print Settings" -> "Support" -> "Style" if you want
Add Infill and Perimeters modifier to "Support Blocker" part
Set Infill Density to 0%.
Set Perimeters, Top and Bottom to 0.
There is four files in the attachment, 3mf, step, stl, f3d
It's time to add tailored support in the original design.
See picture: here I would chamfer the cutout then add two support towers (green) and a one layer support sheet (red).
I have drawn it too wide for clarity, the support towers only need 1mm clearance.
RE: Can PrusaSlicer add a customer support enforcer only above a certain layer?
Diem,
Thanks very much for taking the time to reply. Appreciate the helpful response.
I was coming to the same conclusion as yourself, that I needed to design my own support system, but yours is a far better idea.
One questions is how close does your red support bridge need to be? Is it a layer below so they touch, or two layers below so that there is a layer gap, perhaps 0.2mm, or should I run a series of parallel lines for the top lug to be supported on.
Here's my first design, I'll print it and see what happens
I
While diem's approach works and is arguably the best solution—in particular if you have control over the model—, you can accomplish what you want to do in Prusaslicer as well. Just don't use a support enforcer. (BTW, the blocker doesn't work because once a support is initiated from the top, blockers don't block regions below, because that's not how they work. ) However, if you use paint-on supports—which I vastly prefer over support enforcers—it'll work as expected.
Also, your comment about height range modifiers "just does layer thickness". Uh, not true. I admit, it's not intuitive to find but if you add a height range modifier, right click on the range in the parts panel, and you'll get a whole slew of additional options. Alas, none of them help with your support issue.
I just realized that maybe I misunderstood your design intent. If the nut hole in the bottom lug penetrates the whole lug, what I suggested won't work because the support will extend through the hole. However, you can deal with it by painting a small support blocker on the top of the arc, right above the nut hole.
@fuchsr
Thanks for this. I tried using the paint on supports and they don;t quite work the way I want them to.
I have a square volume in the lower lug. This will hold an M3 Square nut. You can see this here:
I will pause the printer at the top of the square hole at the bottom lug, put a nut in and then continue the print.
The problem is if I paint on the supports as shown below
and then slice. I get the bottom square hole with support material as well
You can see the square with the green support material.
I am not an expert in PrusaSlicer and if there is a way to paint the supports so that they only go upwards and not downwards, please point me to the right place.
PrusaSlicer does seem to do an awful lot, but it does rather hide its functionality. I can see why, but itif I can do what I'm after any otherway, I'm happy to try.
Currently I'm printing test supports to see how they look and work.
Appreciate all the help and if there's a page someone can point me to, I'll happily look there. I did spend a long time looking though.
Thanks
Rob
That's a more tricky situation because with paint on supports, PS treats the top surface of the insert hole as a legitimate start point for new supports. You'd have to use the clipping function to expose that surface and paint a blocker on, but I found my hands to be too clumsy to get the clipping tool to do what I want to…
As this is a functional part and the cosmetic affect is unimportant I would make the support bridge sheet itself the bottom layer of the upper part. Then break off the support towers and a quick pass with a sanding block to tidy the edges.
@diem,
I'm working on the bridge you suggested. I have the bridge designed and thats fine. It's a little tight but got the bridge OK. I have a series of thin supports on the top and this is the area I'm working on. I'm trying to work out how thin they can be and how far apart they can be. I can use a scalpel to cut some of it and sand as suggested but my supports aren't as good as the ones PrusaSlicer creates. This is the latest version as I try to create as few supports as possible.
Getting there (but slowly)
I'm trying to make this as easy as possible to break off as this is not a one off.
I really do appreciate the input here.
Thanks
Rob
Your support is much more massive than needed. It only needs to take the weight of two or three layers, after that *this part* will maintain itself.
Apologies, only just seen this. The issue for me is that if I turned the clamp over so the nut hole is on the top, that affects the other side of the clamp in much the same way 🙂 However I now know how to do support blocking through painting.
@diem, yes you are correct, however when I was designing it, I had issues with first layer adhesion and so I created it larger with a larger footprint to get the thing to stick.
I'm going to get the top vanes working so it is supported correcttly, then I'll reduce the size of the support bridge to something smaller. I was using PLA on a Satin sheet initially, but am now back to PETG on Satin sheet, so things are sticking better now.
I'll get the size down at the end.
Thanks
Rob
@rwillett
Split to Parts
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
@ringarn67
Thanks for this. I have done what you sugested and am laughing as I have absolutely no idea what you have done, how and why, but it works. I have support between the lugs AND a square volume inside the lower lug that doesn't have support.
I looked at the F360 file and can see that have created a square volume inside the lower lug with a cylinder coming through. That matches what I have.
The rest of what you suggest is much the same as me trying to explain compiler design to my dog 🙂
I will need to unpick what you have suggested and why so I can understand it. This is way beyond what I have ever done, I have never looked at "Snug" in "Print Settings" -> "Support" -> "Style".
I think (but could be wrong) I can see that changing the infill to 0% and top and bottom parameters to 0, fools PrusaSlicer into thinking that there is something there and therefore no support is needed, when in fact there isn't.
I'm genuinely impressed with this. I am still laughing and shaking my head as this is nth level hacking and I'm still at Level 0.
Let me read and learn, and I'm delighted that I have something new to think through.
Many thanks
Rob
@ringarn67
Feel free to ask and I will try to answer the best i could. I know my F360-file is a bit clumsy, I just wanted to test it as fast as possible 😊
"Snug" keeps the support tighter, with style set to "Grid" support will swell out a bit. If you change between them difference is pretty obvious.
That is exactly what I think is happening. 👍
Many thanks
Rob
Your welcome, and thanks to You I learned something new
I've rebuilt the Fusion 360 file to work with the sacrificial part. This is the whole pictiure
and here's the lower clamp with the sacrifical part in place
I'm printing now to see if it all works with captive square nuts
