Can one create new user-defined GCode macro variables for Prusa Slicer?
I have some macros that repeatedly reference a long macro expression. It would be great to set the value to a user-defined macro variable and then just reference the user-defined macro variable.
I saw in the PrusaSlicer documentation that there is a well-defined list of pre-defined macro variables but I want to have a custom variable.
Note: I am talking about macro variables that are evaluated at slicing time, not GCode variables that are evaluated at run/printing time.
Thanks
RE: Can one create new user-defined GCode macro variables for Prusa Slicer?
[...] I saw in the PrusaSlicer documentation that there is a well-defined list of pre-defined macro variables but I want to have a custom variable.
I spent a lot of time working with PrusaSlicer/Slic3r gcode and processing and I'm unaware of any such capability. I think the closest you'll come is to either:
- Use a post processing script which will be called by PrusaSlicer after slicing.
- Create a script that sets up the variables and settings you want, then call PrusaSlicer via the command line interface. This is the approach I used.
I do wish PrusaSlicer had this sort of capability. It would be great to allow one setting to reference another (e.g., maximum layer height = nozzle size * 0.8). You can try making a suggestion on the PrusaSlicer GitHub page where the developers are likely to see it. These pages are mostly for user-user support.
Sounds like you might want to try Super Slicer, specifically this version https://github.com/supermerill/SuperSlicer/releases/tag/2.3.57.5 onwards.
Be aware that while based on Prusa Slicer it is not the same. The very similarities can be enough to be a gotcha as certain settings behave differently and it allows you to tweak many more settings so its not really for beginners.
Thanks but this feature is not do-or-die for me and given that, I would rather stay with Prusa.
Perhaps though the Prusa folks could back port the function...
My opinion, just learn how to use Slicer as it is now, you can do anything you want with it.
Just depends on how good you are.
Good Luck
Swiss_Cheese
The Filament Whisperer
