Can I execute g-code commands automatically when I use the 'resume' button after manually pausing a print job?
Chris Hill
(@chris-hill)
I've just added a nozzle wiper to my CORE One, and have tweaked the Start G-code settings in PrusaSlicer so that the nozzle is wiped on three occasions (just to be absolutely certain!): once before the nozzle is initially homed, once before the mesh bed levelling, and once after the initial purge line (just in case anything got left on the nozzle).  It seems very effective.
What I'm missing now is a way to force the same few g-code commands to be run after a pause (manual or pre-programmed), when I press 'resume'.  Typically there will be some extra purge/ooze at the end of a pause, and it needs a bit of dexterity to pull this off the nozzle before the print restarts.  I expect that the resume process is managed by the firmware, rather than separate g-code, but I thought I'd ask the experts here in case there's a way to trigger a nozzle wipe as part of the resume process.
Respondido : 27/04/2025 2:18 pm
1 les gusta
