Can I disable PrusaSlicer's builtin unload GCode when using non-prusa MMU?
Serhii
(@serhii)
I'm using PrusaSlicer with Voron 0.2 and I've built Enraged Rabbit Carrot Project for it. I've calibrated the thing to quite good results and want to have first test print, but what I'm experiencing is that when I use custom GCode for tool change PrusaSlicer still adds it's own unload code. Is there a way to disable it?
Thanks
Best Answer by Serhii:
In "Filament Settings" set everything under "Wipe Tower Parameters" and "Toolchange parameters with single extruder MM printers" to zero, including ramming parameters.
Found this only by looking into Prusa Slicer code itself. It's quite weird to not have this setting tbh.
Napsal : 28/07/2023 2:23 am
Serhii
(@serhii)
Napsal : 28/07/2023 10:34 pm
