Can I change which extruder is assigned after "apply color change automatically"?
If I have a MMU and slice a sign model and accept the "apply color change automatically" prompt it appears that it starts with tool 0 and then assigns the next color change level to tool 1. If I had the color I actually wanted to use for that first color change loaded in tool 3 is there any way to tell Prusa Slicer to use tool 3 instead of tool 1? I haven't found a way to set this.
Postato : 20/07/2022 5:48 am
Topic starter
answered:
RE: Can I change which extruder is assigned after "apply color change automatically"?
I found it, you have to click on the x at the color change and select edit and there it allows you to change the extruder.
Postato : 20/07/2022 6:08 am
