Can I add multiple modifiers of same type?
Ben V
(@ben-v)
I'm looking to add modifiers at multiple heights so I used the "height range modifier" and set the first range (0-1.46mm) and then wanted to set an additional modifier from 2.51-5.24 and when I try and do that, it modifies the initial one, doesn't add a new one.
Any thoughts on how to do this? I'm on 2.9.0
-ben
Veröffentlicht : 24/02/2025 6:55 pm
RE: Can I add multiple modifiers of same type?
Yes you can.  Once you have added one height range modifier theres a plus icon to the right of it on the list view.  Click that to add further ones.
You might want to look through the basics first via the prusa knowledge base https://help.prusa3d.com/article/modifiers_1767#height-range-modifier
Veröffentlicht : 24/02/2025 7:14 pm
That little plus sign is easy to overlook though.
Veröffentlicht : 24/02/2025 7:40 pm
That's why its mentioned in the documentation (what little there is of it)
Veröffentlicht : 24/02/2025 7:53 pm
