Can filament settings be changed per object?
I have a filament that gives different textures at different temperatures. Is there a way I can change nozzle temperature (and other filament settings) specifically per object and without changing the extruder?
Postato : 26/09/2025 1:06 pm
RE: Can filament settings be changed per object?
Alter the settings in the g code and insert M109 S (DEGREES C ) to whatever layer height
What filament are you using, interested.
Postato : 26/09/2025 4:03 pm
Topic starter
answered:
- Thanks for the tip. I am using TPU Air by Siraya Tech. Shore hardness can range from 85 A to 65 A as temperatures range from 230C to 270C. One other filament setting that needs to be tweaked at is extrusion multiplier; the higher the temperature, the lower the flow rate needs to be, coming to as low as 55%. Any help is appreciated! 🙂
Postato : 26/09/2025 4:31 pm
