Calibration Auto Towers
Rigger64
(@rigger64)
Utenti
Is there any chance of seeing Auto Towers in PrusaSlicer? like what they have in Cura,  Like a heat tower & flow rate Tests & not being well versed in writing G-Code (i am trying & giving it a good crack), i wanted to run some tests on my printer (Voxelab Aquilia X2) the other day & i knew i had seen the Towers somewhere then i remembered that "Cura" has them installed so i went to "Cura" got what i wanted Saved the 3MF files then sliced them in PrusaSlicer & run them on my machine (BTW: my Printer seems to like PrusaSlicer G-Code files over "Cura").
I thought it would be good to be able to work with something that im getting better using (PrusaSlicer) as opposed to using Cura which I'm not keen on & i find PrusaSlicer much easier to use as it has some excellent features but if we could get the Auto Towers that are in "Cura" into PrusaSlicer it would be an excellent feature to have.
TIA
Questa discussione è stata modificata 2 years fa da Rigger64
Postato : 30/09/2023 3:44 am
RE: Calibration Auto Towers
Idea's like this would be best raised on Prusa Slicer GITHUB, where the developers hang out.
Postato : 30/09/2023 8:08 am
1 persone hanno apprezzato
Rigger64
(@rigger64)
Utenti
Thank you for your suggestion i will head there soon.
Regards Rob
Postato : 30/09/2023 11:09 am
