Build PrusaSlicer for VS2019
Davide
(@davide-5)
Hi, as the title suggests, I've been trying to compile PrusaSlicer 2.2.0 for Visual Studio 2019 for some time, without success. I have followed the procedure through CMake, but I keep getting only error messages. I downloaded and installed the boost libraries it required, and fixed a problem, if another occurs, this time requesting the tbb libraries, which I downloaded and added the path in CMake-gui, still getting errors.
Is there a pre-compiled version of PrusaSlicer for Visual Studio? Or would someone be kind enough to share it?
Thank you.
Sorry the translator.
Salve, come da titolo sto cercando di compilare da un po di tempo PrusaSlicer 2.2.0 per Visual Studio 2019, senza successo. Ho seguito la procedura tramite CMake, ma continuo a ricevere solo messaggi di errori. Ho scaricato e installato le librerie boost che richiedeva, e risolto un problema, se ne verifica un'altro, stavolta richiedendo le librerie tbb, che ho scaricato e aggiunto il percorso in CMake-gui, continuando a ricevere errori.
E' disponibile una versione di di PrusaSlicer precompilata per Visual Studio? O qualcuno sarebbe cosi gentile da condividerla?
Grazie.
OS: Windows 10 64bit
Postato : 29/09/2020 7:31 pm
Utenti
RE: Build PrusaSlicer for VS2019
I have read a lot about it.  I am not sure what the benefit would be other than to say you did it.
Postato : 29/09/2020 7:42 pm
Davide
(@davide-5)
I want to make some customizations, and take the opportunity to practice in C ++, I don't have to tell anyone.
"I have read a lot about it." Do you mean about my problem?
Postato : 29/09/2020 8:02 pm
