Bug? Top layers not filled when height range dependent ironing enabled
Nik
 Nik
(@nik)
Hey all,
I believe I found a bug in PrusaSlicer. Please see the attached 3mf file - when I enable ironing in the height range modifier, the filled top layers are no longer being generated/only follow internal structure rules. When I disable it, the print generates fine.
Here is an attempt to capture the problem in a screenshot, you are seeing the last layer before the ironing (and it is not filled):
This post is meant both as a possible bug report, and/or to ask if there is a way to work around this problem - I am grateful for any ideas.
Opublikowany : 26/07/2021 8:09 pm
