BUG in GCODE: Missing retraction in some movements
PrusaSlicer 2.3.0 (Windows 64bit)
Ive found bug in generated GCode. Some movements were made without previous retraction, even when move length is longer than "minimum travel after retraction" parameter (2mm in my case).
Bad code looks like that:
| G1 | X85.779 | Y107.154 | E1.80653 |
| G1 | X85.919 | Y95.819 | F4800.000 |
| ;TYPE:External | perimeter |
Second instruction (movement without extration) is 11,3mm so it is long enough and should be made with retraction.
Btw. In other part of the file there is proper retraction (1.5mm) before movement like this (retraction is in second line):
| G1 | X80.607 | Y89.951 | E12.26002 |
| G1 | E10.76002 | F2100.000 | |
| G92 | E0 | ||
| G1 | X88.792 | Y97.063 | F4800.000 |
| G1 | E1.54000 | F2100.000 | |
| ;TYPE:External | perimeter | ||
| G1 | F1800.000 | ||
| G1 | X89.267 | Y96.637 | E1.59801 |
It is
RE: BUG in GCODE: Missing retraction in some movements
Hi, not much point in posting here. It's not where the developers hang out. PRUSA has a GitHub site for PrusaSlicer. You should file a bug report there, if you want the developers to see it.
Retractions are not made on every move. Several factors affect where they occur. That last G1 is either extruding 1.59801mm more filament if the extruder is in relative mode, or 12.26002-1.59801 (-10.66201mm) if in absolute mode.
This is no problem in relative/absolute mode, but with missing retraction. This bug causes serious problems in prints: when nozzle is moved over already printed part without retraction, some amount of filament leak (or rather is sucked out) from nozzle and glued into printed part, so when next perimeter is printed there is not enough filament in nozzle and beginning of perimeter is missing. In my print it causes visible gap in perimeter.
Fuchsr is quite correct, this is not the place for bug reports. Its a user to user forum and the Dev's rarely visit here. You need to open an issue on the prusa slicer github located at https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Don't forget to include a copy of your saved 3mf project file (zipped up into an archive) as well as a clear concise description of the issue as well as all the other information requested when opening an issue.
I've already reported it on github.
Btw. You may control retraction by option: [x] Only retract when crossing perimeters.
When unchecked retraction is triggered always and problem disappears.
(the question is: moving nozzle over existing perimeter should be trated as crossing perimeter or not?)
