BUG: How do I remove the old Mini/Mini+ printer profile in PrusaSlicer?
When I added the "Mini & Mini+ with Input Shaper" printer to PrusaSlicer, the process didn't automatically remove "Mini & Mini+" (the one without the Input Shaper) from the list. Now they are both listed, and I cannot remove the old printer profile.
This is also the case on our makerspace laptop's PrusaSlicer, and it's very annoying to explain to new people because they often forget and choose the wrong one and then they're confused when they get a warning message when printing.
I have run the configuration assistant, and in the printer section there is only one option for the Mini/Mini+, and it says "Input Shaper". When I deselect it and finish the configuration, the "Mini/Mini+ with Input Shaper" printer profile is gone, but the original "Mini/Mini+" profile is still there and cannot be removed.
I searched the forum for other people asking about this, in case I was missing something. Some people said you can edit the list of printers by editing your PrusaSlicer config file, but I don't have enough expertise to do that - and I shouldn't have to. This seems like an obvious bug.
Best Answer by lw36:
In the configuration assistant, scroll all the way down, under "Legacy profiles Family" you'll find the Mini without Input Shaper and you can deselect it.
In slicer, go to the configuration option.
Then configuration wizard.
Go into Prusa Research (for FDM printer selection) .
Untick the printers you do not want on the local copy of Prusa Slicer.
Click finish.
then let it run its course and when its done, it should remove the printer.
Its not a bug 🙂
Shane (AKA FromPrusa)
RE: BUG: How do I remove the old Mini/Mini+ printer profile in PrusaSlicer?
AHHHHH thank you so much, this is such a relief! My nervous system is soothed. 😀
