Brim goes around support footprint but not the build footprint
Snebular
(@snebular)
Is there anyway to fix this issue. I have found no options for the brim other than it's size. Putting the brim around the support footprint does nothing to help bed adhesion for the print and is impossible to print some things without changing slicers. Is there an option I am not seeing. Also sorry for the weird screenshots I can't seem to figure out how to take one with only the one monitor needed
Postato : 09/02/2021 6:10 pm
RE: Brim goes around support footprint but not the build footprint
Simple answer is nope. That’s the way PS does it.
btw on windows if you select the program you want to screen shot you can hold down alt at the same time you press print screen and it will only copy the active window/program to the clipboard.
Postato : 09/02/2021 6:34 pm
Snebular
(@snebular)
@neophyl
Ah well thanks but that sucks I hope it gets fixed eventually cause that kind of ruins most of the usefulness of the this slicer. Also thanks for the help with the screenshot usage
Postato : 09/02/2021 7:16 pm
