Bridge infill over cut text
I've bumped into this very annoying issue. I'm trying to print something with a 0.2mm text cut on the bottom. All layers are 0.2mm, the cut is 0.2mm.
The problem is on the second layer where I get solid infill around the contour of the text and bridge infill over the text (at various angles also).
Obviously I'd like for the second layer to be solid infill to look the best and not risk visual defects.
There's also no control over the angle of the bridge infill which would also help alievate some of the annoyances.
Ce sujet a été modifié il y a 3 years par Andrei X
Publié : 06/05/2023 11:04 am
