Brick Layers
Steve Weathernam
(@steve-weathernam)
Brick Layers
Does anyone have Brick Layers working in PS?
Opublikowany : 31/05/2025 8:38 pm
RE: Brick Layers
Not familiar with that function name. What exactly are you referring to.
Opublikowany : 31/05/2025 8:40 pm
Walter Layher
(@walter-layher)
RE: Brick Layers
Probably this:
Opublikowany : 31/05/2025 8:56 pm
RE: Brick Layers
That function does not exist in Prusa slicer. It was introduced into super slicer and orca took it from there.
Opublikowany : 31/05/2025 9:09 pm
Walter Layher
(@walter-layher)
RE: Brick Layers
The video mentions a script that can be added in PrusaSlicer: https://github.com/TengerTechnologies/Bricklayers
I have not tried this.
Opublikowany : 31/05/2025 9:12 pm
Steve Weathernam
(@steve-weathernam)
RE: Brick Layers
OK, I'm a little surprised there's been so little interest. I tried to implement the process from this github page: https://github.com/GeekDetour/BrickLayers . It implements a Python post-processing script to parse gcode files and generate brick layers. My issue is that it can never find either Python itself or the script (not sure which).
Honestly, I was thinking some people must have tried it and, hopefully, at least one got it working, so I could piggyback on their experience.
Opublikowany : 31/05/2025 9:14 pm
Walter Layher
(@walter-layher)
RE: Brick Layers
Some years ago I used a prost-processing script for Arc Welder in PrusaSlicer, but then I switched to using the arc-welder plugin on OctoPrint. I am using Linux, the github page I mentioned seems to be targeted at Windows users, the other one gives examples for all platforms. On Linux it works if you enter the whole path for the executable(s) into the configuration. Should be also valid for Windows environments.
As to why I haven't tried it yet: so far I am content with the strength of the parts I have printed. Not everyone breaks prints as a hobby like Stefan. 🙂
Opublikowany : 31/05/2025 9:25 pm
This. I can certainly see use cases for it but personally have little need for it. I'd rather that after all those years PS gave me the option to draw straight seam lines without having to resort to undocumented features.
Opublikowany : 31/05/2025 9:57 pm
Steve Weathernam
(@steve-weathernam)
RE: Brick Layers
Can't disagree with anything you say. Mostly I wanted to try it, see what it can do. I'm no longer getting the error (after redoing the Output Options entry) but it also doesn't seem to do anything. Checking exported gcode file just seems to show regular old layering.
Opublikowany : 31/05/2025 10:01 pm
Steve Weathernam
(@steve-weathernam)
RE: Brick Layers
Oh, BTW, Stefan only got about a 10% improvement in strength with PETG, so......
Opublikowany : 31/05/2025 10:06 pm
RE: Brick Layers
Now I'm on a PC and not my phone and have seen the video I was getting it mixed up with alternate extra layers setting from SuSi/Orca.  I'm like the others, can't really see the point of it at the moment.
It's like a lot of the new stuff, just doesn't offer enough of an advantage (like the scarf seams which make mine look worse) to be worth tinkering with.  I'll probably try it if they add it natively but until then got too much other stuff to be doing.
Opublikowany : 31/05/2025 10:23 pm
Steve Weathernam
(@steve-weathernam)
RE: Brick Layers
exactly what I'm thinking. Too much work for 10%.
Opublikowany : 31/05/2025 10:26 pm
Suni Mü
(@suni-mu)
RE: Brick Layers
i wonder if this could help with making small pipe adapters (more) airtight. Anyone tried it yet?
Opublikowany : 14/09/2025 5:17 pm
glossyio
(@glossyio)
RE: Brick Layers
Here's an interesting application of brick layers for making waterproof / submersible prints: https://hackaday.io/project/204613-brick-layers-making-3d-prints-super-waterproof.
I ended here when I searched for the setting in PrusaSlicer.
Opublikowany : 17/12/2025 6:50 pm
Smitje
(@smitje)
RE: Brick Layers
I would be very interested in this, we do a lot of prototyping on our 2 MK4s and some free extra strength would be a huge benefit as well as improved whater tightness and pressure resistance.
In a recent project we had a lot of trouble with a pare failing due to fatigue caused by repeated impact. Brick layering would likely be a huge improvement there because the staggered fuse-lines woud reduce crack growth.
I'd love to try it. Did anyone get the script working? Or is there any indication that this will be incorporated?
Opublikowany : 05/03/2026 11:13 am
Snuffleupagus
(@snuffleupagus)
I'm sad to see this implementation being asked for in the community, so many things of much greater importance have been asked for and straight up ignored,
it's clear to me that what was and is important is not only being ignored, but is being accepted for what sells more printers. I'm so sad to see things like this in the community, I've watched for years as basic things much more impotent, have been ignored.
Good luck,
Regards
This post was modified 4 months temu 2 times by Snuffleupagus
Opublikowany : 07/03/2026 12:19 am
vinlaell
(@vinlaell)
Wow man I don't even know what to say to this comment that's like saying why would anybody want lower taxes when they could be asking for world Peace
Sorry it's just that it is a useful feature and it is a fine thing to ask for
This post was modified 3 months temu by vinlaell
Opublikowany : 22/03/2026 7:12 am
mnentwig
(@mnentwig)
RE: Brick Layers
actually 10 % from a single, software-only improvement seems very significant to me. Will definitely look into it when the time comes. It also makes sense intuitively (I think...)
Opublikowany : 22/03/2026 7:22 am
