Bottom support interface
mdressel
(@mdressel)
Is there a way to use a different material for the bottom interface when using organic supports? I would like to save on tool changes by having only the bottom and top interfaces for supports that are generated on the interior of a part to have a different material. Right now I can only get the top interface to be a different material. The bottom interface layers aren't even an option when you select 0 for "top contact Z distance".
Opublikowany : 27/12/2023 11:10 pm
RE: Bottom support interface
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-how-do-i-print-this-printing-help/soluable-interface-organic-support-and-wipe-tower-problems/#post-689472
Organic supports don't have a bottom interface layer.
Opublikowany : 27/12/2023 11:25 pm
1 ludzie polubili
mdressel
(@mdressel)
Perfect! Thank you very much for the quick response.
Opublikowany : 27/12/2023 11:43 pm
