Borders open or top most layer with too much space between lines
Hi, I have an Ender 3 v2 using Prusaslicer 2.5.0 (download 3mf file) and I have tested the following different options but I coundn't solve the problem of too much space between lines:
A) Added more top solid layers: 4, 5 or 6
B) Changed minimum shell thickness different from zero
C) Increased infill from 15% to 20, 25 or 30%
I half solved activating the iron option (topmost surface only 15, 20, 30%) , however even with ironing I had problems. How can I fix it? Thanks!!
Veröffentlicht : 04/01/2023 7:58 pm
