Blank "Send to Connect" window in PrusaSlicer
Brian Cox
(@brian-cox)
I'm using PrusaSlicer 2.8.1 on a Widows 11 computer and I'm logged into my Prusa account inside the Slicer.
When I click the "Send to Connect" button inside PrusaSlicer, the "Choose a printer" window pops up, but it is blank.
Also, if I click the "Prusa Connect" tab inside PrusaSlicer, it comes up blank as well.
I've provided screenshots below.
I tried changing my default browser to Firefox, Chrome, and even Edge. But that did not fix the problem.
I appreciate any suggestions!
Opublikowany : 13/10/2024 6:17 pm
RE: Blank "Send to Connect" window in PrusaSlicer
Seems to be a semi common problem, https://github.com/prusa3d/PrusaSlicer/issues/12969
Opublikowany : 13/10/2024 9:15 pm
Brian Cox
(@brian-cox)
Thank you. The only fixes discussed on this page seem to be related to Linux.
Hopefully a solution will be available soon.
-Brian
Opublikowany : 14/10/2024 4:06 pm
D Wilson
(@d-wilson)
I have exactly the same problem using MacOS BigSur, Firefox or Safari browsers
I have tried everything, but cannot cure the problem.
I hope someone can find a fix.
Opublikowany : 09/12/2024 10:37 am
