Best support material config for printing mini's using 0.25mm nozzle @ 0.07mm
Hi all,
I'm trying to print mini's on my prusa mk3s+ with 0.25mm nozzle but I'm struggling that supported areas, aren't really that supported and yields gaps as shown in the attatched image
Currently I'm using following settings for supports
Contact Z distance 0.1mm
Pattern: rectilinear
pattern spacing 1mm
pattern angle 0 degrees
interface layers 2
interface pattern spacing 0.15mm
don't support bridges
Which yiels following support in the slicer view, which looks okay to me
Is someone here printing small parts as well that need supports, which tips & tricks should I apply?
Opublikowany : 24/07/2021 5:30 pm
