Before and after slicing - A lot of detail is missing
stupidjerry79
(@stupidjerry79)
Brand new here.  Please take a look at my before and after slice. What happened?
Thanks!
Opublikowany : 11/01/2022 6:32 pm
Tracy
(@tracy)
RE: Before and after slicing - A lot of detail is missing
On the Print Setting tab, turn on Detect thin walls.
Opublikowany : 11/01/2022 6:51 pm
stupidjerry79
(@stupidjerry79)
That made an improvement, but still a lot of broken lines compared to the preslice pic
Opublikowany : 11/01/2022 6:56 pm
Probably not enough.  Rework the design with walls a minimum of two extrusion widths thick; 0.9mm, although better to go twice that.
Cheerilo,
Opublikowany : 11/01/2022 7:03 pm
Swiss_Cheese
(@swiss_cheese)
Or turn it off if its already on, and adjust your extrusion widths.
The Filament Whisperer
Opublikowany : 11/01/2022 7:18 pm
or adjust XY Compensation to say 0.2mm
Opublikowany : 12/01/2022 1:12 am
1 ludzie polubili
Milos V.
(@milos-v)
In short. Those lines are too thin. Depending on the nozzle you use (suppose 0.4mm), you logically can not without issues print lines that are thiner then nozzle diameter. With all what was adviced you somehow print it. but never identically. Sure you could change the nozzle to 0.25mm, but it will print long time.
If you are not binded with size, you can also scale it up, then the lines will be thicker, and printable.
Opublikowany : 12/01/2022 9:46 pm
