Bad printing from Prusa (same cura its okay)
BAC Track
(@bac-track)
Hi, I started printing from ASA 275.
Temperatures 210/55
Flow 96%
I'm printing this object it's just a test. And you can see the result in the photos.
Printing from Cura is great, but the same from Prusa slicer is warped.
I usually have default values. As I wrote flow 96% (Cura adjusts further still flow 91% to support)
The width of the supports are both 0.42mm and the height is 0.2mm
I have both dialed in as much as possible the same, it works.
But the print from Cura has 20% more weight. Despite the Cura giving me lower flow when printing supports, which makes up the majority of the print.
What am I missing with the Prusa?
I've printed it about 10 times and halfway through the print +- it starts to curl. Let's not address the temperatures. The problem is elsewhere.
If I need to add any information, I'll add it.
PS: I see 255 layers in the cura, and 433 in the Prusa. Even if it's the same object, why is it so different?
thanks
Napsal : 11/06/2023 3:55 pm
