Avoid thiny lines in Archane generation mode
Is there a way to avoid ~1mm thiny lines in Arachne permieter generation mode? The slicer puts down multiple thiny (~1mm) lines then later on it connects to the other permieters. I understand the logic but unfortunately my printer is not able to reliably print that small pieces even with a very slow (~12mm/s) speed. The little piece will grabbed by the nozzle then stick somwhere else massing up my print.
Is there any chance to change this other then switching the permieter generation mode?
Thank you in advance!
Kind regards!
Respondido : 18/10/2022 8:48 am
