"avoid crossing perimeter" not applied on some layers
bastl
(@bastl)
Hello together,
is there a possibility to mark this blue travel-lines (s. images) and drag them inside the printing?
Else this print is not possible for me -> the print gets ripped off at first crossing blue line.
Or I have to make a print bed layer first, but it feels that it crashes, too. This part is so fragile and small.
"avoid crossing perimeter" = 800 mm
Prusa Slicer 2.9.0
Many thanks for helping!
Opublikowany : 25/02/2025 3:16 pm
Sometimes the geometry of a shape makes it impossible to print without crossing perimeters, perhaps the parameter should be renamed "avoid crossing perimeters when possible."
Your part has a tiny footprint, to give it more grip on the bed try adding a brim.
Opublikowany : 27/02/2025 10:26 am
bastl
(@bastl)
RE: "avoid crossing perimeter" not applied on some layers
If it would take the shortest path to get in the mode "avoid crossing perimeter" again, like a car on the street when a solid line is in the middle and an accident on its track. And not take the next curve and crossing on the wrong side, too ...
But to drag the blue lines where you want them layer by layer as a wish would be nice.
Now I closed this cutout with a thin wall, that it gets yet recognized and did 2 prime layers and it worked out.
But cleaning such a tiny part from its prime is frustrating ...
Opublikowany : 28/02/2025 10:39 am
