Automatic slicing from folder and export to usb?
Jimbo
(@jimbo-4)
Hello.
I have been using Prusaslicer for about 4 years now...and it works great.
I am looking to get things done faster
My cad is already setup with a single button to export to stl and save in a folder with the name stl1, stl2 etc automatically.
is it possible when a new file is created in a folder starting with first 3 letters stl to automatically get sliced in Prusaslicer and export the gcode to usb?
My pla Prusaslicer settings never change and I do several versions a day...so I am trying to save some time here.
Tnx!
Questa discussione è stata modificata 6 months fa da Jimbo
Postato : 06/11/2025 12:57 am
_KaszpiR_
(@_kaszpir_)
RE: Automatic slicing from folder and export to usb?
Maybe with a scripting via inofiy to watch given directory for new files, run peisa slicer cli to slice it and generate a new gcode and maybe directly export tot he printer via sliver in th cli if possible ( not sure), or another script or tool to sync between the computer and remote usb
Postato : 06/11/2025 9:03 am
1 persone hanno apprezzato
yahbluez
(@yahbluez)
Posted by: @jimbo-5
Hello.
Tnx!
This will do the job:
inotifywait -m -e close_write --format '%w%f' /path/to/your/folder | while read filename; do /path/to/your/script.sh "$filename"; done
It waits until a new file is written to /path/to/your/folder
then runs
/path/to/you/script.sh  /path/to/your/folder/new_filename
It runs infinite and calls your script for each new file ones. your script is called after the file is written.
Postato : 07/11/2025 10:00 am
Jimbo
(@jimbo-4)
Thank you for the info.
Bear with me...where do I put these lines of codes?
Inotify is a windows item?
Tnx!
Postato : 07/11/2025 5:24 pm
inotify / inotifywait is originally linux but it has been ported.
You are basically daemonising the process - turning it into a background task.  If you are not familiar with shell programming you might be wise to drop the plan.  You need to use .bat / .cmd batch scripts - the commands that underlie windows.
Postato : 07/11/2025 8:17 pm
2 persone hanno apprezzato
Jimbo
(@jimbo-4)
Tnx...I guess I will drop it for now.
Postato : 19/11/2025 1:29 am
