Auto Speed and Supports slowing down everything
Hello,
I tried to setup Autospeed today. So I set all speed vallues to Zero. I set Max Printspeed to 100 mm/s and Max Volumetric Speed to 15 mm/s.
Thats working. The outer Perimeter print with about 65 mm/s. But when I now enable Supports the whole print slows down a lot to about 29 mm/s with the same settings. I just enabled support.
Is this a Bug? Or can anybody explain this? What is the solution? Does anybody use Autospeed frequently with success? Is it worth it?
Opublikowany : 25/02/2021 3:34 pm
Topic starter
answered:
RE: Auto Speed and Supports slowing down everything
I just found out that I can solve it by setting the Support Material Interface speed lower. When I set it to like 10 or so the Overall speed is 60 mm/s again. But this looks buggy to me.
This post was modified 5 years temu by HolgerholleBolle
Opublikowany : 25/02/2021 3:49 pm
