Auto Arrange Settings? Need more space
Tim
 Tim
(@tim-11)
Is there a setting to increase the spacing between parts used by the auto arrange feature?  More space allows for more even cooling and it pulls strings out further making them easier to polish off after the print.  I know I could just move the parts by hand but I am printing 50+ copies of small parts and would like them to have more space by default.
Veröffentlicht : 30/06/2020 12:13 pm
RE: Auto Arrange Settings? Need more space
Not in Prusa Slicer no.  In Super Slicer (which is built on Prusa Slicer so would be very familiar) theres a setting under Print Settings>Output Options called Distance between copies.  It actually also controls the distance between objects during arrange too.  I use it to get things really close together when theres lots of them but you can set it to a higher value and then arrange and it pushes them apart.
Its available here https://github.com/supermerill/SuperSlicer/releases
It installs into its own directory so your Prusa Slicer install isnt effected.  If you need to copy any custom profiles over you can open Prusa Slicer and save config bundle to somewhere on your machine and then in Super Slicer use Import Config Bundle and all your customised settings will be copied over.
Veröffentlicht : 30/06/2020 5:32 pm
MihaiDesigns
(@mihaidesigns)
Right-click on the arrange button and increase the distance.
Veröffentlicht : 06/02/2021 10:47 pm
3 weiteren Personen gefällt das
Crashoverride
(@crashoverride)
Right-clicking is the way to go! I don't know when they implemented this - but it's great!
Diese r Beitrag wurde geändert Vor 7 months von Crashoverride
Veröffentlicht : 18/09/2025 3:13 pm
