Anyone know what's going on here? Slicing problem
Andrew Smith
(@andrew-smith)
Here's my parts pre-slicing
But once I slice, the base layers seem to vanish.  Any ideas?
Cheers,
Andrew
Opublikowany : 30/07/2020 12:34 am
KOBALT3D
(@kobalt3d)
RE: Anyone know what's going on here? Slicing problem
Just thinking... Are you using standart profiles? Maybe providing project file with one model will help progress further. You can cut away upper part of the model if you don't want share it.
Opublikowany : 30/07/2020 7:16 pm
Easiest would be if you could save your parts & settings as a 3MF project file, zip that, then upload it here as an attachment. That way we can see all of your relevant details at once.
Opublikowany : 30/07/2020 7:25 pm
Posted by: @andrew-s41
Cheers,
Andrew
Very sparse information. A project file would be very useful to analyze errors. Maybe you analyze your STL data using netfabb or a similar STL check/repair tool.
Opublikowany : 30/07/2020 7:26 pm
Andrew Smith
(@andrew-smith)
@kobalt3d
It turn's out, no.  Sorry I'm new to this.  I'd opened up a 3mf file that changed them.  Then started a new project and they hungover and impacted a few other gcodes.  This became apparent when I plugged the SD card into the printer and it told me the gcodes were for a different printer.
All sorted now, thanks 🙂
Cheers,
Andrew.
Opublikowany : 31/07/2020 1:27 am
