Any way to get back the auto repair in Slicer 2.5
KLAUS
(@klaus-3)
I have been working with older versions of Prusa slicer for a while, I recently updated to 2.5.0.
I used to load a OBJ or Stl file into the slicer and it would auto repair it , see below.
I just realized that version 2.5 does not do this any more, can this fuctionality be turned back on?
I see there is now a repair STL function, I tried that but it did , not fix the errors and rescaled my object.
The older versions worked really well, to auto easily repair everything I loaded in, what happent to this feature, Why?
Thanks
Respondido : 24/07/2023 2:23 am
KLAUS
(@klaus-3)
RE: Any way to get back the auto repair in Slicer 2.5
Just to update seems like it may be doing some repairs, but defiantly does not work like it used to in older versions.
I have tested it with the same files, and the new version does not fix things completely like the old system did, now some files will not slice .
Any way i can get this old repair functionality on the new versions of Slicer?
Thanks
Respondido : 24/07/2023 2:49 am
KLAUS
(@klaus-3)
Also wondering is there any way to get a auto repaired model out of the older version of slicer, If i export the plate as STL it dose not come out with the repairs that were made?
Thanks
Respondido : 24/07/2023 3:11 am
Hello
(@hello)
Go file save project save then open the 3mf file it saved
Respondido : 24/07/2023 3:24 am
Hello
(@hello)
Also I use the version before the new one that's out on github and it works fine
Respondido : 24/07/2023 3:28 am
KLAUS
(@klaus-3)
So are you saying that if I use Save a Project from an old version of slicer, where an object has been imported and auto repaired.
Then if I open up slicer 2.5 , and use Import 3mf , that will open up the old project with the previously auto repaired model?
"Also I use the version before the new one that's out on github and it works fine"   What version exactly are you referring to  to  v 2.5 ? that works fine.
There defiantly seems to be a difference in the auto repair functionality, from the older versions and 2.5, (as mentioned I tested the exact same models in both and V 2,5 failed to make all the corrections, it's like the newer version got worse in this regard) I whish I knew why?  or how to get the better older auto repair  in 2.5  .
Thanks
Esta publicación ha sido modificada el hace 3 years por KLAUS
Respondido : 24/07/2023 3:51 am
Hello
(@hello)
Yes and I use the version before new one and autorepair works the same for me
Respondido : 24/07/2023 3:54 am
