Any way to adjust seam transitions?
Ian C
(@ian-c)
I'm new to PrusaSlicer, and I've been trying to figure out why my seams are not as nice as some of the other software I've used - I think I know why that is the case and hoping someone might know how to adjust this.
When transitioning from inner perimeter to outer, at the location of the seam, the software places the start of the outer perimeter behind the end of the inner perimeter, resulting in the machine having to 'backtrack' a small amount, resulting in a short pause as the axes must perform 2 reversals. I believe this short dwell is causing the majority of the seam.
I've tried a few things, but without success. Ideally the start point of the external perimeter should be either beside, or slightly ahead. In the image below, this would be the 3 -> 4 transition, which causes the axes to backtrack.
Any ideas are appreciated!
Ian.
Postato : 31/12/2021 7:46 pm
