Amount of filament layer by layer
brianjordan
(@brianjordan-2)
Is there anywhere in Prusa Slicer 2.9.4 showing the amount of filament used on individual layers?
Thanks B
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Opublikowany : 19/12/2025 12:49 pm
RE: Amount of filament layer by layer
Simple answer is no.
Opublikowany : 19/12/2025 12:59 pm
brianjordan
(@brianjordan-2)
Thanks. I thought as much but I often miss things...
B
Opublikowany : 19/12/2025 1:36 pm
Wish there was a better answer for you but I have never seen anything for layer weight.  I'd be happy to be proven wrong too as that way I learn something new 🙂
One thing you can do if you want to know how much something weighs up until a certain point is to temporarily add in colour changes using the slider.  Then when its sliced you can look at the slice preview and change to colour.  That will tell you have much of each colour you are using.
Not what you wanted but its sometimes useful for determining roughly where a partial roll will run out as you can see the print time until the change and plan accordingly.
Opublikowany : 19/12/2025 8:33 pm
